2 members (Gdads51, Jon G), 100 guests, and 0 robots.
Topics128,049
Posts1,055,691
#789956 10/18/2011 9:53 PM
1 Offline
Is their a way to convert over a electric choke over to a manual choke? or do i just have to buy a new one and swap it in? is it an easy/cheap swap? its on a 1987 350 engine that i pulled/plugged all the emissions stuff.
1 Offline
Ive got a single barrel carburetor from a 1964 283 that had a manual choke on it, would i be able to swap that over?
Riding in the Passing Lane
Those electric chokes are basic & usually work good trouble free. You should be able to make it work. If you dont have current going to the coil after aborting the factory system you can hook the wire to a circuit that is hot when the ign. is running. The choke should go shut when cold. To test the choke Hook a jumper wire to the choke coil & a hot wire The choke should gradually open up.
If you are running the original carb with out the electronics it will not get good gas mieage.
1972 Chevy c10 Cheyenne Super
What was the purpose for disabling the emissions equipment? The electric part of the choke is designed to be sure the choke valve opens fully within one minute if the temperature is above 70 degrees F., and within 3 minutes below that. It's a very simple oil pressure controlled circuit, and disabling it makes no sense at all. Installing an automatic choke cover without the heater strip doesn't work because there's no hot air system built into the carburetor to provide the heat necessary to make it release properly.
If I'm reading this right, you pulled this engine and installed it in something else?
Without the electronics and the emission stuff it won't run quite right and it won't be as economical on fuel.
1 Offline
Yes, when we bought the engine it didnt come with the wire harness, we figured the carbd 350 without the emissions stuff would be just about the same as the 1964 283 that was in the truck before. So what im reading about the choke is that if i hook up a hot wire to the choke it will work properly? i thought that maybe it needed something else, but i dont know much.
You should also find a vacuum diagram for your setup. You will want to make sure that the choke pull off is working and also the vacuum advance for the distributor.
