8 members (cmayna, Gray_Ghost, Donf, Otto Skorzeny, Gdads51, Jon G, Forty9, Shade Baby),
104
0
Mod | | | Forums66 Topics128,118 Posts1,056,307 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | just been to look at another truck
part restored/rebuilt here,s the details. being sold as a 1955 2nd series
body number = m255ko38183
chassis/frame number = 53l123942
engine (gm7)cast number 523293
engine number = a34715028
trans ca-56 number = 5899
what can any body tell me about any of the above
engine and trans has been rebuilt but trans may have a slight leak?? on the toruas seal ??? i,m not familier with this model of trans all brakes and supsension componants are new only body work ,wiring,and glass to do and i think the price maybe ok
any help will be gratefully recieved
thanks .mike..
live or die do it with spanner in hand
| | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | oh also
it has a 12 bolt rear end
is this desirable ???
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | The engine is a 1957 Pontiac 347 . Does it have a Hydramatic transmission? Put m255ko38183 in the VIN BUSTER and you will see this is a 1955 Chevrolet 3200 (3/4 ton) | | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | hi, GMONIZ i thought it was a 3100
the trans is said to be a 4 speed without a park position ??
strato-flight ??
does that meen anything ??
| | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | is the 347 any good i was told that it maybe of pontiac origen but it was said to have come out of a gmc truck and i think i saw gmc cast on it
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | GMC used Pontiac engines. My 59 engine is painted red. I think they are good engines. | | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | GMC used Pontiac engines. My 59 engine is painted red. I think they are good engines. who make,s tubelar headers for 247,s ?
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | "Strato-Flight" was Pontiac's name for the Hydra-Matic transmission. It's a 4-speed automatic with direct drive in 4th. gear and a fluid coupling, not a torque converter. The parking lock is engaged by puting the shifter into Reverse with the engine stopped. The Pontiac V-8 was used as original equipment in GMC trucks, not Chevrolets. Tubular headers are usually good for raising the underhood temperature, leaking exhaust gas at the header-to-cylinder head gaskets, and burning spark plug wires. The only place they give a measureable power gain is at high RPM, so unless you're planning to do a lot of full-throttle running, I believe the problems aren't worth the gains. Jerry
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | spanners, I mis-spoke. Your truck is a 3200 and that's the designation for the 1/2 ton long bed. 123" wheel base The 3100 was 113' wheel base 1/2 ton short bed | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | spanners, I mis-spoke. Your truck is a 3200 and that's the designation for the 1/2 ton long bed. 123" wheel base The 3100 was 113' wheel base 1/2 ton short bed Wouldn't the GMC model be a 100? Equal to a Chevrolet 3200? | | |
