1 members (51sub), 128 guests, and 2 robots.
Topics128,125
Posts1,056,338
Members48,440
#789872 10/18/2011 5:24 PM
just been to look at another truck
part restored/rebuilt
here,s the details.
being sold as a 1955 2nd series
body number = m255ko38183
chassis/frame number = 53l123942
engine (gm7)cast number 523293
engine number = a34715028
trans ca-56 number = 5899
what can any body tell me about any of the above
engine and trans has been rebuilt but trans may have a slight leak?? on the toruas seal ???
i,m not familier with this model of trans
all brakes and supsension componants are new
only body work ,wiring,and glass to do
and i think the price maybe ok
any help will be gratefully recieved
thanks
.mike..
live or die do it with spanner in hand
oh also
it has a 12 bolt rear end
is this desirable ???
The engine is a 1957 Pontiac 347 . Does it have a Hydramatic transmission?
Put m255ko38183 in the VIN BUSTER and you will see this is a 1955 Chevrolet 3200 (3/4 ton)
hi, GMONIZ
i thought it was a 3100
the trans is said to be a 4 speed without a park position ??
strato-flight ??
does that meen anything ??
is the 347 any good i was told that it maybe of pontiac origen
but it was said to have come out of a gmc truck and i think i saw gmc cast on it
GMC used Pontiac engines. My 59 engine is painted red. I think they are good engines.
who make,s tubelar headers for 247,s ?
"Strato-Flight" was Pontiac's name for the Hydra-Matic transmission. It's a 4-speed automatic with direct drive in 4th. gear and a fluid coupling, not a torque converter. The parking lock is engaged by puting the shifter into Reverse with the engine stopped. The Pontiac V-8 was used as original equipment in GMC trucks, not Chevrolets. Tubular headers are usually good for raising the underhood temperature, leaking exhaust gas at the header-to-cylinder head gaskets, and burning spark plug wires. The only place they give a measureable power gain is at high RPM, so unless you're planning to do a lot of full-throttle running, I believe the problems aren't worth the gains.
spanners, I mis-spoke. Your truck is a 3200 and that's the designation for the 1/2 ton long bed. 123" wheel base The 3100 was 113' wheel base 1/2 ton short bed
Wouldn't the GMC model be a 100? Equal to a Chevrolet 3200?
