5 members (tclederman, DadsFirstPickup, 59 fleet, IHPWR, Ponchogl), 102 guests, and 4 robots.
Topics128,107
Posts1,056,225
Members48,436
#78951 05/23/2007 9:04 PM
Junior Member
Junior Member
has anyone had trouble with new spark plugs going bad? I can buy a new set of plugs and in a week or so 1 or 2 will go bad. The plugs are running really rich in color. do you think it maybe the float setting in the carb,making it fowl plugs.Any help please also it's a 235 chevy.
#78952 05/23/2007 11:06 PM
Riding in the Passing Lane
It doesn,t take much of a rich mixture to carbon up the plugs with todays gasoline. If you are driving it regular & they are getting black you are running too rich. If it,s all slow & idleing, moveing around the shop you have to clean them occasionally. The extended tip plugs work the best. Like AC R46s. I bought some Champion plugs a while back & they broke real easilly & there was nothing in side the insulator, Just space. I keep a spark plug sand blaster in the shop & clean the plugs on the trucks we are working on when nessesary. They are available from the discount tool shops for $20-25.
1972 Chevy c10 Cheyenne Super
#78953 05/24/2007 4:09 AM
Junior Member
Junior Member
so how do i correct running to rich is it by adjusting the air mixture screw, or adjusting the float level. doug
#78954 05/24/2007 9:15 PM
The air mixture screw only adjust the idle mixture. I take it you have a Roch. model B carb. You will need to take the top off the carb. & check the float level. Make shure the power valve is working & the vacuum passage in the base of the carb has passage to the intake manifold. The ignition & timing need to be right also. The size of the main jet is stamped on the jet. Make a note of it. There has been a lot of posts on this in this websight. You may want to do a search for some more info.
#78955 05/24/2007 9:20 PM
wynns55,
If the engine is worn out, poor compression and burnt leaking valves, it will have a tough time burning even a proper mixture of air/fuel. If the sooty material on the plugs is anything but dry black soot, you have oil control problems which will also foul plugs.
Stuart
#78956 05/25/2007 3:40 PM
Junior Member
Junior Member
Thanks guys on the advice. The compression is 100lbs across all six,the timing I havent't done yet 6 volt everything else has been replaced coil ,wires,points it maybe be the vacuum under the carb is plugged. doug
#78957 06/19/2007 6:03 PM
Junior Member
Junior Member
wrenchbender rocks
My 1950 chevy has been running rich and fowling plugs for awhile now, and after posting my problem on this site (wrenchbender ret) diagnosed the problem. I had covered the vacuum port under my carb which was making my plugs foul out.,good for me bad for the local NAPA PARTS store.
