0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78951 05/23/2007 9:04 PM | Joined: Oct 2005 Posts: 33 Junior Member | | Junior Member Joined: Oct 2005 Posts: 33 | has anyone had trouble with new spark plugs going bad? I can buy a new set of plugs and in a week or so 1 or 2 will go bad. The plugs are running really rich in color. do you think it maybe the float setting in the carb,making it fowl plugs.Any help please also it's a 235 chevy. | | |
#78952 05/23/2007 11:06 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It doesn,t take much of a rich mixture to carbon up the plugs with todays gasoline. If you are driving it regular & they are getting black you are running too rich. If it,s all slow & idleing, moveing around the shop you have to clean them occasionally. The extended tip plugs work the best. Like AC R46s. I bought some Champion plugs a while back & they broke real easilly & there was nothing in side the insulator, Just space. I keep a spark plug sand blaster in the shop & clean the plugs on the trucks we are working on when nessesary. They are available from the discount tool shops for $20-25. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#78953 05/24/2007 4:09 AM | Joined: Oct 2005 Posts: 33 Junior Member | | Junior Member Joined: Oct 2005 Posts: 33 | so how do i correct running to rich is it by adjusting the air mixture screw, or adjusting the float level. doug | | |
#78954 05/24/2007 9:15 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The air mixture screw only adjust the idle mixture. I take it you have a Roch. model B carb. You will need to take the top off the carb. & check the float level. Make shure the power valve is working & the vacuum passage in the base of the carb has passage to the intake manifold. The ignition & timing need to be right also. The size of the main jet is stamped on the jet. Make a note of it. There has been a lot of posts on this in this websight. You may want to do a search for some more info. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#78955 05/24/2007 9:20 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | wynns55,
If the engine is worn out, poor compression and burnt leaking valves, it will have a tough time burning even a proper mixture of air/fuel. If the sooty material on the plugs is anything but dry black soot, you have oil control problems which will also foul plugs.
Stuart | | |
#78956 05/25/2007 3:40 PM | Joined: Oct 2005 Posts: 33 Junior Member | | Junior Member Joined: Oct 2005 Posts: 33 | Thanks guys on the advice. The compression is 100lbs across all six,the timing I havent't done yet 6 volt everything else has been replaced coil ,wires,points it maybe be the vacuum under the carb is plugged. doug | | |
#78957 06/19/2007 6:03 PM | Joined: Oct 2005 Posts: 33 Junior Member | | Junior Member Joined: Oct 2005 Posts: 33 | wrenchbender rocks
My 1950 chevy has been running rich and fowling plugs for awhile now, and after posting my problem on this site (wrenchbender ret) diagnosed the problem. I had covered the vacuum port under my carb which was making my plugs foul out.,good for me bad for the local NAPA PARTS store. | | |
