0 members (), 136 guests, and 3 robots.
Topics128,110
Posts1,056,241
Members48,437
#789330 10/16/2011 8:59 PM
Any hints or things to look out for swapping out a 250 straight 6 w a 3 on the tree for a v8 327 w/ auto trans?
Found out after messing with this engine it had a couple dead cylinders, 30 pounds of compression in them and 2 bad valves and a cracked/repaired block.
My brother is giving me a 327 that has 26K miles on it with an auto trans.
I see all the posts mostly talk about 350 swaps. Should I assume there wont be much difference with the 327?
It is going in a 64 short stepper.
AzMcCoy #789338 10/16/2011 10:11 PM
You'll have to add a crossmember/mount for the tail of the tranny, and remove the 6-cyl. "spacers" for the side motor mounts.
Have fun.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
If it is a newer LS 327 and electronic controlled tranny, you are going to be adding a bunch of computer controlled components and all new wiring. Older 327 with carburetor and mechanically controlled tranny will be very similar to any other SBC install.
mikew #789836 10/18/2011 3:04 PM
Thanks for the information.
It is out of a 1968 so it does not have computers. Original 2 speed automatic trans also. Don't know if I should bother with updating the tranny or not.
My 64 has a 12 bolt rear end with 3:73 gears but is not a posi trac. I assume this will work okay with that configuration.
I'd stick with your original 3 speed, easier swap and less trouble down the road
Don't throw away the adapters on the 250 block that connect to the motor mounts. Someone will want them.
Same with the p/s pump brackets.
regards,
Leon
Leon #790153 10/19/2011 2:01 PM
I forgot to ask.
I would guess the original Radiator wont be enough to cool the new motor, especially if I add power steering and air conditioning to the mix.
What would be the best radiator to look for in a salvage yard?
I'd agree that a 48 year old radiator might turn out to be a weak spot in your refurbished truck. But before replacing it with another one with unknown history, I'd suggest checking to see what a new one would cost. For example, Autozone offers their CU284 for $215 with a lifetime warranty. P&A may be different in AZ, but its worth asking.
regards,
Leon
Leon #790203 10/19/2011 4:43 PM
Original 6-cyl. radiator is smaller than V-8 unit. I bought new V-8 one (LMC) for when I swap from 250 to sbc, but haven't put it in yet. Don't know yet how mounts & shrouding will end up.
$215 is cheap!
cm
1965 Chevy C10
