0 members (), 136 guests, and 2 robots.
Topics128,035
Posts1,055,560
#787523 10/10/2011 4:11 AM
I
I Offline
I am installing a classic performance products power steering box on a 54 1/2 ton and having a tough time visualizing how it is mounted. Does anyone have a photo (jpeg) that shows their installation? Thanks. Bob
Swaps like this are discussed in the HiPo forum. Try a search there.
Hi Bob
Here is a link to some photos of my CPP power steering installation.
It's in a 51 half ton panel, but set up is identical.
The only change I made after these photos was to move the column
down and outboard slightly to accommodate the column shift
for the 455 Buick mated to a T400. If you are using a floor shifter, then
don't worry about it.
Just make sure you "measure twice and weld once" when installing the
mounting plate for the steering gear and make sure you use the spacers in the kit
to locate it properly outboard of the frame. You'll also have to cut off the end of the original steering arm off the spindle.
Highly recommend using their BIG tie rod, and ends, & their stabilizer bar.
The power steering really puts a strain on the old stuff, so go big and beefy.
I have about 150 miles on this set up now it it steers and stops great.
mike
http://gallery.me.com/squire001#100109
Fitted this conversion on my '50 truck for several years ago -it works really well. There's a photo of the setup here And there are some more photos on my website - it's linked in my signature.
Best of luck with the conversion, Stuart.
I
I Offline
Thank you for this. I will give it a look. I really appreciate the insights. Bob
I
I Offline
Thank you. I am finding my way around the web site. I will look there. Bob
I
I Offline
Thank you for this. I know it has been said before, but I am amazed at all the help available on this site. Thanks again. Bob
1 Offline
Sounds like a GREAT tech tip in the making! Either that, or I just haven't found it yet.
