| | | Forums66 Topics128,089 Posts1,056,432 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 62 | checked for vacume leaks at carb intake vacumeadvance wipper hole pluged.carb was resently rebuilt and ran ok till now.whith carb choked at low idal 19 inch pounds runs rough. thanks
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sounds like you have water in your carb.. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Sounds like you have a restriction in the fuel line. Fuel may be getting there but may be low on pressure. Hook up a fuel gauge and see how much fuel pressure is getting to the carb. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | There is a good chance you have trash in the main metering jet. A quick fix that works quite often is to take the top off of the carb and sucking the trash out with an eye dropper. Just because the carb was rebuilt recently doesn't mean that you haven't gotten fresh trash out of your tank or fuel line. | | |
