8 members (Hotrod Lincoln, tclederman, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom, Otto Skorzeny),
182
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2003 Posts: 17 Junior Member | | Junior Member Joined: Jun 2003 Posts: 17 | Ya stovebolters how are you doing,been a while since I have been here.I need your guys help with a 283 rear main seal change I did with the engine in truck pulled the pan and pulled out the top half of the seal.When I was tapping out the seal I scratched the shaft where the rear main seal sits,will a scratch on the crank hurt anything help. thanks for the help. | | | | | Joined: Jun 2002 Posts: 29 Junior Member | | Junior Member Joined: Jun 2002 Posts: 29 | In a metal scratch its not the groove that's so bad but the metal heaped up next to the groove. I am not sure the best way to get rid of the heaped up part. Like anything it depends on how big I guess. I'm thinking of doing the same job. Let me know how it works | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If you have already put it back together, I would leave it be. At the worst you'll wear out another seal. If you're lucky it will be okay.
If it's still apart, take some fine emery cloth and smooth the surface on the crank. You will probably need to work all the way around the crank, it's one of those jobs where there's no stopping point. I'd pull the spark plugs to make it easier to turn the engine.
Fred 52 3600 69 C-10
| | | | | Joined: Jun 2003 Posts: 17 Junior Member | | Junior Member Joined: Jun 2003 Posts: 17 | hey guys thanks for the response with the rear main seal I used emery cloth on the shaft.I put the new seal in the motor went in perfect then put the right gaskets back in put the pan on.It works perfect no leaks!!!So if you are going to try this on your engine good luck and take your time. | | |
