0 members (), 162 guests, and 4 robots.
Topics128,089
Posts1,056,139
Members48,435
#787613 10/10/2011 4:32 PM
Looking for some info, I got a early Chevy 292 inline 6. I want to beef it up and put it in my 54 chevy truck with a NV4500 and 3:08 rear. I want to get the most power and economy out of it. So far im wanting to bore it 60 over (brings it to a 301), RV cam, it has a 8:1 compresion and i want to at least bump it up to 9:1. I have fuel injection for it, offenhuser 4 bbl intake, full length dual headers.
Ive never build a motor before and this is just an idea that i have. If anyone has a better idea or a better way to build this with great power and economy for street use please reply.
1955.1 Chevy 3600 NAPCO Truck
1957 Chevy 6400 US FOREST SERVICE
Here's a long list of all my STUFF!
Beast57 #787632 10/10/2011 5:37 PM
Drew
DrewP #787668 10/10/2011 8:37 PM
Excellent advice. Buy it!
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
DrewP #787676 10/10/2011 8:46 PM
For any build, make sure everything inside is clean, properly lubricated, clean, properly torqued, and clean. And oh, yeah, did I say clean?
Stuff on the outside can be changed relatively easily, but you don't want to have to go back inside, after squishing gaskets and putting on a nice paint job, just to fix something that shouldn't need fixing.
I'd go with a Holley 500 carb and cast iron headers. I think the limiting factor will be head flow, so you might consider some port work, to enhance the cam. FI might give better mileage, but I don't know much about the setup.
Good luck, and have fun.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
starfire4 #787754 10/11/2011 1:49 AM
So this sounds like a good build? Sounds OK to me. Im sure i will be doing some extensive work to it.
Beast57 #787776 10/11/2011 3:01 AM
All the previous is on target, especially the clean.
The fuel injection you have is a TBI?
Federal Mogul natural gas pistons will get you a little over 9:1 compression.
Starfire4 is right on with the head being the limiting factor. Another limiting factor is getting a quench in the combustion chamber.
Larry
I don't own a vehicle that isn't old enough to drink.
LGriffin #787781 10/11/2011 3:08 AM
Join Inliners International. Lot's of Inliners run this engine.
Cletis #787809 10/11/2011 4:43 AM
ooo i will check that out! For as the fuel injection i have both a Holley 2D Projectiong or a TBI from a 1993 suburban
Beast57 #787879 10/11/2011 2:52 PM
Also, check out www.hotrodinlines.com
Drew
DrewP #787884 10/11/2011 3:15 PM
great power and economy are enemies
panic #787891 10/11/2011 3:47 PM
I belive you can get both. Im sure there is a point where both can be modestly achived.
panic #798345 11/16/2011 9:00 AM
1 Offline
I have a I6 292 running in a street rod and it has a head reworked by Sissell's Automotive in West Covina, CA. All I can say is as I leave the V-8's behind is "C ya later!" This thing is fast!. I shift it a 7,200 RPM's and it just keeps going on using a triple intake with Weber carburetors (expensive but trouble free) and a set of custom made headers. How many old '32 Chevy's do you see run all day long at 70 MPH on the Freeway?
Normbc9
Oh please give me sissell phone number, I have been looking for them for over a year now...Oh never mind I went to dex and got it, the covina part is what I was missing.
panic #799611 11/21/2011 3:45 AM
sps Offline
Drew are you gonna hop up that 292 I gave ya? That would be very cool. Good luck Beast I wish I could hear and see it run.
So, those were your pistons I ran over on the freeway?
panic #799668 11/21/2011 1:08 PM
knuckle head
knuckle head
The drag race 292's rev much higher than 7200....But drag engines run for very short durations and get frequent tear downs.
An inline 6 can beat any V-8 that has less power grin
A 292 with less than 250 hp is somewhat easy to build and is mildly expensive.More power than that is much more expensive.
sps Offline
I picked up the special collector's edition Hot Rod Deluxe, best of the best. Had some very cool gassers with straight six's in them. You might check it out.
sps #800187 11/23/2011 3:56 AM
I'm doing some head work with gasket matching and have talked with Larry in FL http://www.t6racing.org/ about him doing lump ports on the head, but that's a winter project(maybe). I'll send a pm as i progress.
Drew
1 Offline
Brokenhead,
I have used Sissell's for years now. Every head or inline OHV engine they have helped me with is an exceptional performer. Good luck.
Normbc9
Do you have a ballpark figure of what the head work costs?
I have a 292 in my '63 Chevy II. I am running a Holley 390, Offy intake, cast iron headers, and a schneider racing cam (264h).
I'm told that with the stock head, it should be making around 210hp and 290 tq. For $800 in head work, I'd be at 250-260 hp and 325 tq.
Here are some pics:
292 in a '63 Chevy II
