1 members (baldeagle),
91
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 134 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 134 | Does a chevy 40's valve cover stright 6 fit a gmc 40's motor.. just for the use of cutting the top off and be able to adjust the valves on a running motor without the oil going all over the block,, thanks kat unless someone has an old gmc one thats trash...
I like fixing stuff.
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I think you will find that the GMC engines are longer so no interchange on the valve cover. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | My question is, why adjust them with it running? It just ruins a good feeler gauge.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | My question is, why adjust them with it running? It just ruins a good feeler gauge. Amen. | | | | | Joined: May 2009 Posts: 134 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 134 | gm even makes a wrench to do just that... it has the box end wrench and a flat blade built in... so one can to this alone.. feeler in one hand tool in the other,,, or I guess gm thinks its wrong to have a motor in operating temp.. or oil flow that coats the push rod ends and taps... a real world knock or no knock discovered right then... thats a bit tuff to tell with a motor not turning... done my valves four times and there is one that is taping so loud.... so I will find out which one.. it must have a grove that the feeler covers and cant tell... once I find the one,,, I will take it down a few thousands and if the really loud taping stops I'm good... I like it that they all tap a bit... but I got one thats off.. and the rods are all straight...
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | katrina, What would be the GM part number for that tool? My guess is that it would have been a Kent-Moore tool, if it was a GM tool? I see no special tool mentioned in Chevrolet truck or GMC manuals. I have seen a non-GM Zim-Zip valve adjusting tool that sounds like the tool your describe. That tool could be used with any valve adjustment technique (and makes it easier). I have seen Chevrolet Truck Shop manuals give specific warnings about how to make sure that the engine temperature is warm and stabilized. Before adjusting valves using either technique, the engine must run until temperature is properly stabilized. And, the Chevrolet Truck Shop Manuals state that after reaching a stable warm temperature, the valve cover may then be removed and the valve stems should then be lubricated. I have not read a specific reference in a Chevrolet Truck Shop manual that the valves should be adjusted with the engine running or the engine not running. I can easily determine where a knock is and where a loose valve is, by using a cheap stethoscope with the engine running. Then, that valve could be adjusted tighter with/or/without the engine running. Of course, I would have first made sure there are no grooves in the face of the rocker arms - this will also allow feeler gauges to last longer. I have no old GMC manuals but I have a 47-54 manual. Usually, the GMC manuals have clearer descriptions of techniques - in the case of adjusting valve lash I cannot find as much information as stated in the Chevrolet manuals. | | | | | Joined: Sep 2011 Posts: 4 New Guy | | New Guy Joined: Sep 2011 Posts: 4 | Mac tool guy sells the tool you are looking for. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I think the running engine procedure is for hydraulic lifters. Your GMC does not have them. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2009 Posts: 134 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 134 | great advise guys thanks a million
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | before I got the rockers refurbished I used a feeler gage cut to the width of the groove in said rocker arms. You kind of have to dress up the little curly bit that happens when you cut them but it worked fine. I sent my rockers and shaft to larrowe and sons in sandy OR, they put bronze bushings in the shafts, and faced off the rockers, very nice job. | | |
