1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#787199 10/09/2011 1:43 AM
I installed a new rear tail light harness on my 64 k10. Electical worked perfectly before replaced everything. Now the left signal blinks in the "hazard" sequence. The right tail light works fine. Brake lights work fine too. Only the left signal when switched has the hazard light sequence. I mounted the bed with rubber bushings/pads. I first thought the tail lights lost ground with the bushingsz/pads in place....I ran a ground from each taillight to a clean bolt ....thinking I've got ground.
Any one have thoughts on what might be going on? I should also add that I have running lights on the roof and the now blink withe the left signal too.
Appreciate any thoughts. John
1964 K10 Fleetside Pickup Truck
My thought is you have managed to hook the blinking roof lights in parallel with the left signal light. The relay blinks faster because you have increased the current load through it by adding the roof lights. Just pull the bulbs in the roof lights and see if the left turn light doesn't "calm" down. If it does, then start to look for the uh-oh.
