6 members (Gdads51, tclederman, sron48, FAST55, Hambone, cmayna), 149 guests, and 1 robot.
Topics128,111
Posts1,056,258
Members48,437
I'm building a 57 Cameo and want to use stock gauges. I'm using a 96 Corvette engine. How do I get the gas gauge to work right?
regmudd
what engine you use has zero effect on how the gas gauge works - if you have a stock tank, sender and gauge, just wire it up as original
It's not a stock tank as the Corvette engine needs more fuel pressure so I was likely going to use tha Corvette tank, sending unit, etc.
the particular tank has nothing to do with fuel pressure, that's the fuel pumps job, but if you prefer using a non-original tank, you need to find a sender for it that's 30 ohms [generic sender], which is what the original gauge requires, the vette one will be 90 ohms or more
Where do you get the sender that's 30 ohms?
regmudd
check around your FLAPS, one of them will have universal senders in all the usual values - look like this, adjustable for the depth of the tank
3B Offline
Hy regmudd, I would use the stock fuel tank and buy an external high pressure pump to run the fuel injection. You will have to install a return line into the tank, I think there is enough room on the sending unit flange to drill and tap it for a 1/8" n.p.t. connection, and then use whatever fittings that are appropriate to install the return line, hope that helps.
