1 members (TooMany2count),
119
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 54 | I'm building a 57 Cameo and want to use stock gauges. I'm using a 96 Corvette engine. How do I get the gas gauge to work right? Thanks, regmudd | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | what engine you use has zero effect on how the gas gauge works - if you have a stock tank, sender and gauge, just wire it up as original
Bill | | | | | Joined: Jan 2006 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 54 | It's not a stock tank as the Corvette engine needs more fuel pressure so I was likely going to use tha Corvette tank, sending unit, etc. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the particular tank has nothing to do with fuel pressure, that's the fuel pumps job, but if you prefer using a non-original tank, you need to find a sender for it that's 30 ohms [generic sender], which is what the original gauge requires, the vette one will be 90 ohms or more
Bill | | | | | Joined: Jan 2006 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 54 | Where do you get the sender that's 30 ohms? regmudd | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | check around your FLAPS, one of them will have universal senders in all the usual values - look like this, adjustable for the depth of the tank Bill | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy regmudd, I would use the stock fuel tank and buy an external high pressure pump to run the fuel injection. You will have to install a return line into the tank, I think there is enough room on the sending unit flange to drill and tap it for a 1/8" n.p.t. connection, and then use whatever fittings that are appropriate to install the return line, hope that helps. | | |
