7 members (Forty9, fonz8261, jkreiner, treegrower, Bill Hanlon, Wally / Montana, TexasJim50),
51
0
Mod | | | Forums66 Topics128,074 Posts1,055,914 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | Wired up my horn on the '50 tonight. Probably been 5-6 years since this thing has had power. Here is a pic http://i157.photobucket.com/albums/t72/jss1956/DSCN1562.jpgWhen I push the button the horn sounds terrible. I mean it definitely sounds like a serious case of strep throat. Any idea of what to do next? Is there an adjustment or a place whre I can give 'em a cough drop? Seriously, it sounds pretty bad. Suggestions?
It never costs more to ask and it never costs more to think big.
| | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | jss1856 although my Horn is different, check inside... Mine had the same problem with the sound... I cleaned it up and adjusted it... I checked mine with a wires directly from the battery as I have not wired it in the steering column yet... Also check for good contact on your horn button...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | jss1956's horn is the correct single horn used on 47-52 trucks.
healingbear's horn was used as single horn in 1953-1955st; and, was one of the accessory dual-horns sold by GM from 47-55.
I think that a horn relay was not used with single horns until 1953; but, a horn relay came with the dual horn set (high-note and low-note clamshell horns) in earlier years.
