3 members (Napco Man, dunfire, 68ironhead), 214 guests, and 2 robots.
Topics128,081
Posts1,055,955
Members48,430
#787034 10/08/2011 2:38 AM
Wired up my horn on the '50 tonight. Probably been 5-6 years since this thing has had power. Here is a pic http://i157.photobucket.com/albums/t72/jss1956/DSCN1562.jpg
When I push the button the horn sounds terrible. I mean it definitely sounds like a serious case of strep throat. Any idea of what to do next? Is there an adjustment or a place whre I can give 'em a cough drop? Seriously, it sounds pretty bad. Suggestions?
It never costs more to ask and it never costs more to think big.
jss1956 #787050 10/08/2011 3:37 AM
jss1856 although my Horn is different, check inside... Mine had the same problem with the sound... I cleaned it up and adjusted it... I checked mine with a wires directly from the battery as I have not wired it in the steering column yet... Also check for good contact on your horn button...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
healingbear #787102 10/08/2011 1:47 PM
jss1956's horn is the correct single horn used on 47-52 trucks.
healingbear's horn was used as single horn in 1953-1955st; and, was one of the accessory dual-horns sold by GM from 47-55.
I think that a horn relay was not used with single horns until 1953; but, a horn relay came with the dual horn set (high-note and low-note clamshell horns) in earlier years.
