0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | I just wanted to know if a crank gernal thats around .070 out of round is worth having repared , or would I be better off to find another crank & rods. The bearings already say that thier .010 over.This is a 1961 261 motor . Thanks Don
Don
| | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | .070"??? Are you sure? My sparkplugs aren't gapped at .070". Now .007" is a different story. Since you can turn that crank a maximum of .030" under and its already .010", .030"-.010" is .020" meat left on journals. So .020"-.007" is .013" extra, so you're OK if runout/wear is .007" If you actually have .070" runout, you've got a 80 lb boat anchor. Somebody check my math. Chiphead
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There has got to be a decimal place error here for in order to create wear, the engine had to be running. I don't think you could get to .070 out of round without it going to pieces. | | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Exactly. Last year I dismantled a '67 Poncho 400 motor that had a .070"-.100" gouge on a rod journal... When it barfed a rod through the oil pan. :o
Chip
| | | | | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | Gentlemen , this is the measurments I found , I already talked to a fellow inlinner , and he told me I was sunk . The good news is , "if there is any", I still have a couple of motors to dissasemble to find a usable crank. I am trying to to do this as inexspensive as posible, like evry body else. This motor is the cleanest I have worked on yet. I sure hope the block is good.I plan on making this motor a little hot rodded, so if I have to find good parts , I will. I took these measurments in my garage , with my tools , there is room for error. thanks
Don
| | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Hope you can salvage a crank out of the other engines. When you finish, post the parts you don't need on the swap meet. That's what I'm going to do when I finish my 235.
Good luck
Chip
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Hey Jr. do me a favor and save all those worn out cranks, I need fence posts for the back yard. Seriously, I think you can use a 235 crank in that 261 just fine.  | | | | | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | I am planning to make a table lamp out of worn 302 crank and flywheel. Also thought about making a coffee table using a 302 block for the base with a glass table surface. Can't stand to get rid of this stuff but can't afford to use it.
Jason
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I hope you plan to beef up your floor, that will be one heavy coffee table, and who wants a 100 lb lamp? You could use a big ol air filter for the shade.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | I am sure glad I made every body laugh. This is the first engine I will be doing myself. Someone told me I could have the crank built back up and returned , without any problems. And that's why I come here, I get several responses to a single question . When all the answers are the same , it's pretty simple. I figured that this crank was a wash when I first saw thaat it took alot of crank movement to make the #6 piston move , when I first took the head off. Thanks a lot guys for the humor. I will send the crank to "JiMerit", for a fence post. Don
Don
