1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78696 06/12/2007 12:59 PM | Joined: Oct 2003 Posts: 24 Apprentice | | Apprentice Joined: Oct 2003 Posts: 24 | I have a 57 Chevy 1/2 ton stepside with 235. I'm getting ready to buy a pre-bent gas line from the carb to the pump. In some of the catalogs they show an inline glass bowl gas filter. Were these orginal equiptment or after market? Also, if they were orginal where would they go in the system? One other question. How does the spring on the thermosat go in, up or down? :hammering: | | |
#78697 06/12/2007 1:09 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | can,t say on the gas filter....on the them install spring or bellows into the engine side or away from radiator...doc | | |
#78698 06/12/2007 1:26 PM | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | | | |
#78699 06/12/2007 4:44 PM | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | My '53 had a glass filter right at the carb inlet. Very pretty. Ditto to Doc on the thermostat. 1951 3800 Be the change you want to see. -hotshoe
#78700 06/12/2007 5:34 PM | Joined: Oct 2003 Posts: 24 Apprentice | | Apprentice Joined: Oct 2003 Posts: 24 | Thanks I installed it with the spring facing up out of the radiator. | | |
#78701 06/12/2007 7:35 PM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I believe GM had given up on glass bowl filters by 57. I could be wrong, ask my wife.
~Jim
