10 members (Johnny Rib, 68ironhead, 2-Ton, 1955 1 Series, JW51, baldeagle, Guitplayer, walter74, Eisenholtz, Peggy M),
104
Mod | | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78671 06/11/2007 10:06 AM | Joined: Jan 2007 Posts: 117 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 117 | i have an 47 3/4 ton and i need a gastank, under the frame , can i make a tank or build one? ???? mick in wisc
care to chat write back
#78672 06/11/2007 2:32 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Welcome to the 'bolt. There have been a ton of threads on under/between frame tanks. If you use the search function at the top of the page you'll find hours of informative reading. click
#78673 06/12/2007 1:43 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#78674 06/12/2007 7:56 PM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Remember Mikester your frame is more narrow than the 3100 models and your crossmember is different and in a different position. I am in the same situation as you and it looks like I will need to move the crossmember back as far as possible in order to install a tank of any size.
~Jim
#78675 06/12/2007 11:49 PM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I bought a 47 3/4T at an auction about a month ago, mainly because it had the stainless windshield and side window trim. It has an under bed gas tank--probably gone on the bottom (I didn't look) that I can get the dimensions off of. What I did notice is that it didn't seem as deep but was longer than one on a 1/2T.
Evan
| | | | | Joined: Jan 2007 Posts: 117 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 117 | well , what i found out i got a new s-10 gas tank from a friend to try out and guess what??? it fits and work and iam cruz nnnnnn ....... mick
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Jim. Where did you buy your gas tank from?
Mickster. Is your s-10 tank for any specific year? Does it mount in back or along side your frame?
I am looking for a frame mount tank to put in the original location on my 48.
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
