0 members (), 166 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#78671 06/11/2007 10:06 AM
i have an 47 3/4 ton and i need a gastank, under the frame , can i make a tank or build one? ???? mick in wisc
care to chat write back
#78672 06/11/2007 2:32 PM
Ex Hall Monitor
Ex Hall Monitor
Welcome to the 'bolt. There have been a ton of threads on under/between frame tanks. If you use the search function at the top of the page you'll find hours of informative reading. click
#78673 06/12/2007 1:43 AM
i did mine under the bed on a 51-3104
read the details and photos
learn to do a search
see::
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=004252#000000
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=DSC00372.jpg
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=004653#000000
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=DSC00310.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=579990-R1-032-14A.jpg
http://s67.photobucket.com/albums/h...&current=3100lockinghoodlatch-02.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=DSC00370.jpg
Jim & Caroline
#78674 06/12/2007 7:56 PM
Remember Mikester your frame is more narrow than the 3100 models and your crossmember is different and in a different position. I am in the same situation as you and it looks like I will need to move the crossmember back as far as possible in order to install a tank of any size.
~Jim
#78675 06/12/2007 11:49 PM
I bought a 47 3/4T at an auction about a month ago, mainly because it had the stainless windshield and side window trim. It has an under bed gas tank--probably gone on the bottom (I didn't look) that I can get the dimensions off of. What I did notice is that it didn't seem as deep but was longer than one on a 1/2T.
Evan
coilover #639456 04/20/2010 11:52 PM
well , what i found out i got a new s-10 gas tank from a friend to try out and guess what??? it fits and work and iam cruz nnnnnn ....... mick
mickster #639605 04/21/2010 3:07 PM
Jim. Where did you buy your gas tank from?
Mickster. Is your s-10 tank for any specific year? Does it mount in back or along side your frame?
I am looking for a frame mount tank to put in the original location on my 48.
TIA
Dennis
