2 members (J Lucas, lumbersawyer), 129 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
#786612 10/06/2011 2:02 PM
Those of you who have switched to a throttle cable, did you prefer a firewall or floor mount pedal system? And why?
Drew
I prefer the Lokar throttle cable kit and have mounted three of them on firewalls in lieu of mechanical linkages. It has a bell crank at the bottom of the pedal assembly that protrudes through firewall/floor. This setup allows you maximum
flexibility in positioning. Fits in very tight quarters.
my 2 cents
mike
I opted for the Lokar, mounted on the firewall, as cable has almost a straight run to the carb linkage.
1940 Chevy KC 1/2-Ton
Okay. Thanks, Mike & Bruce. I kinda thought the firewall is the easier run. And, Bruce, checked you webshots to see your set up. Nice. And your interior is a "wow"!
Drew
Can you use the Lokar cable on a stock 63 chevy truck pedal?
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
Drew...thanks for the compliments
Jon.....check the Lokar website for details. They have a few different options for pedals and cables.
