9 members (Gib70, Gdads51, 78buckshot, Phak1, mo2cyl, Oldcaliforniakid, BC59, Wally / Montana, MickeyP),
81
Mod | | | Forums66 Topics128,049 Posts1,055,667 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Those of you who have switched to a throttle cable, did you prefer a firewall or floor mount pedal system? And why?
Drew
| | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | I prefer the Lokar throttle cable kit and have mounted three of them on firewalls in lieu of mechanical linkages. It has a bell crank at the bottom of the pedal assembly that protrudes through firewall/floor. This setup allows you maximum flexibility in positioning. Fits in very tight quarters.
my 2 cents
mike
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I opted for the Lokar, mounted on the firewall, as cable has almost a straight run to the carb linkage. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Okay. Thanks, Mike & Bruce. I kinda thought the firewall is the easier run. And, Bruce, checked you webshots to see your set up. Nice. And your interior is a "wow"!
Drew
| | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Can you use the Lokar cable on a stock 63 chevy truck pedal?
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Drew...thanks for the compliments Jon.....check the Lokar website for details. They have a few different options for pedals and cables. | | |
