7 members (Uncles51, 78buckshot, Peggy M, Youngin' Tut 59, Cletus1950, delwrench, 1 invisible),
105
Mod | | | Forums66 Topics128,174 Posts1,057,048 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | guys, do you have nay pictures of your radio / cd players mounted in your dash that you could share ? i am gathering ideas since i soon will be getting an a/c unit and will have to move my radio from the glove box. i hate thinking about cutting a hole in the dash where the original radio was, but my truck aint original anyway, so its gonna happen soon.
thanks much
leonard | | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | Ever thought of putting your radio under the seat with a remote to run it. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Leonard, They make aftermarket radios that bolt right in the old spot that have CD, MP3 and USB options. They look and sound great and are not much more than a good modern in dash unit.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | thanks guys... im looking to keep my current c/d radio, not wanting to purchase a new unit. not really sure which way i will go, so thanks for the input.
leonard | | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | Here's a pic of my radio in the glovebox. It is attached to a wood 1x4 using brackets supplied with the radio. The 1x4 is attached with one bolt (see it?) to the lower dash. The original radio faceplate is there for looks. Radio in Glovebox - 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | Oops. I got the radio move au contraire. Yours is in the glovebox already. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
