2 members (Bucker, 1 invisible), 140 guests, and 4 robots.
Topics128,183
Posts1,057,194
Members48,465
HELP! I bought a 1954 chevy one ton 3800 dual rear tires and can not find rear wheel cylinders! the bore is 1 1/4" and the problem is my wheel cylinders have the bolts above the bleeder and all the ones I am getting from Carters and so on are in line with the bleeder screw. Any Ideas!!!! Need brakes to drive truck! Old wheel cylinders are too rusty to re kit.
crockbuyer,
Contact Joe Way at Sierra Specialty Automotive and have him sleeve your old cylinders and put new kits in them. They will be better than new because the brass sleeve won't rust. His email is [email protected]
I have used Joe on many of my projects over the past 12 years, he's easy to deal with.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
3B Offline
Hy crockbuyer, It's possible that someone swapped rear axles on your truck, could you post a picture of the wheel cylinder you're looking for? In the pictures in my brake parts catalogs Raybestos p/n WC18010 ($47.81 @ Rock Auto) is the rear wheel cylinder listed for your truck, and the mounting bolts are only very slightly above the centerline of the bleed screw hole. I assume the cylinders you have been recieving will not bolt into place on the backing plate, is that correct?Just in case you want to compare the Napa p/n is UP 18010, you could go to a store which stocks them and have a look.
I had thought someone changed rear end And ALSO I WILL get the old ones re sleeved if need be THANKS FOR THE HELP!!!!!!!!!!!! Tony
3B Offline
Hy crockbuyer, that sure is a pretty truck, I've never seen those wings on the tops of the fenders before.
The truck has every option radio clock turn siginals
Does it have the optional '54/'55 "Unison Seat" ? Very nice truck.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
If you mean the split seat yes it does
Hey crock,
I had same problem...got the right ones from NAPA but did not line up by a hair.
I used die grinder with 1/2" cutter to make backing plate groove a little deeper.
Also installed stainless steel bleeders.
1954 4400
1954 3800
Jim D.
'41 Chevy 1-Ton Pickup/dump...292" 4-speed w/Ranger OD ... Newest Truck
'54 Chevy 3800 Dump........New Truck!
'54 Chevy 4400 flatbed/dump, Gone to my brother-in-law
'13 GMC 1500 daily driver ... 5.3 6-speed auto just turned 13k miles
'01 Chevy 2500hd, might be my new daily driver ... 6.0 / 4L80-E
