2 members (Tstan7, Napco Mark), 75 guests, and 6 robots.
Topics128,022
Posts1,055,353
Members48,420
#7851 03/14/2005 2:21 PM
I am re-assemmbling my engine and will be putting the clutch back on soon. I am still a novice but would like to know when to replave the clutch? It looks OK but what do I know? I can send a pic to anyone you would like to comment.
#7852 03/14/2005 3:54 PM
I would replace it now. It's a relatively cheap item (especially if your pressure plate is good). It's a lot easier to replace it now than later. Don't forget a new throw -out bearing if you decide to replace it.
#7853 03/14/2005 4:51 PM
8
8 Offline
I'd replace everything, pressure plate included. I just bought a new one for the '51 (with a '54-up clutch). The whole kit cost a little less than $115. It even came with an alignment tool.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#7854 03/15/2005 11:09 PM
Riding in the Passing Lane
If the clutch worked OK before you started I would just replace the disc & TO brg. If you replace whole assembly get a new matched set. The remans are very inconsistant. Dont foget the pilot bearing. smile
1972 Chevy c10 Cheyenne Super
