1 members (klhansen),
90
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 135 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 135 | I'm trying to replace my side vent window. I have the material to "hold" it in place, but cannot get the glass in place. Any thoughts or suggestions on installation? Not sure if there are any special tools I need or tricks to get this in. I want to avoid going to the local auto glass replacement place. Im trying to replace the vent with the vent housing still on the door. I really dont want to remove it Any thoughts? Thanks John
1964 K10 Fleetside Pickup Truck | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You should be able to do it that way. Clean out the channel real good. Use a thin glass material. Wrap the material around the edge of the glass & put it in position. Put a block of wood against it & tap it in. It shouldn't take much. Some times you can put pressure on the glass with your hand & tap the frame. You might put some silicone spray on it to help it slide easier. After it is in take a razer & cut off the excess. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
