7 members (NJC, baldeagle, Gray_Ghost, Peggy M, Wickedbass, Charles in CA, cmayna),
73
7
Mod | | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | I am re-assemmbling my engine and will be putting the clutch back on soon. I am still a novice but would like to know when to replave the clutch? It looks OK but what do I know? I can send a pic to anyone you would like to comment. | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I would replace it now. It's a relatively cheap item (especially if your pressure plate is good). It's a lot easier to replace it now than later. Don't forget a new throw -out bearing if you decide to replace it. | | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I'd replace everything, pressure plate included. I just bought a new one for the '51 (with a '54-up clutch). The whole kit cost a little less than $115. It even came with an alignment tool.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#7854 03/15/2005 11:09 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If the clutch worked OK before you started I would just replace the disc & TO brg. If you replace whole assembly get a new matched set. The remans are very inconsistant. Dont foget the pilot bearing.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
