7 members (Thomaslb, 1955 1 Series, Hanks custodian, Ridgeback, Hotrod Lincoln, Ponchogl, 1 invisible),
46
Mod | | | Forums66 Topics128,090 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78500 06/06/2007 4:25 AM | Joined: Aug 2004 Posts: 45 Junior Member | | Junior Member Joined: Aug 2004 Posts: 45 | Does anyone have a pic of the original push rod type accelerator linkage that goes from the carb to the pedal. I have a 66 and the guy i bought the truck off of had a welding rod stuck in there and i can't even get full throttle. I have check lmc , brothers to no avail. I guess i will have to build one, any other ideas? | | |
#78501 06/06/2007 4:39 AM | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | badriand:
You have a PM.
Tony | | |
#78502 06/12/2007 6:01 AM | Joined: Mar 2007 Posts: 27 Apprentice | | Apprentice Joined: Mar 2007 Posts: 27 | What is the answer? I have the same problem! Not a welding rod, but I have a carb spring that is rubbing on the intake manifold. I recently changed from a 250 to a 292, and it seems the extra height of the 292 has thrown the throttle linkage off. Photos of a correct 292 throttle linkage would be very helpful. | | |
#78503 06/12/2007 1:52 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I use 1/4 rod as similar to original, just cut & bend to your needs. It can be threaded for adjustability if you have the end pieces. | | |
#78504 06/12/2007 1:59 PM | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I found this illustration in one of my manuals. It should be helpful in addressing your throttle linkage issues. \'64-\'66 Chevy Truck Throttle Linkage Good luck with your project. Tony | | |
#78505 06/15/2007 2:43 AM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | I can send you a pic of one from my 66 if you still need it. | | |
