2 members (klhansen, Otto Skorzeny), 47 guests, and 1 robot.
Topics128,036
Posts1,055,452
Members48,422
#784749 09/29/2011 7:46 PM
OK guys..i have a 52 chevy, 3100. 4 speed transmission.(not the 3 speed column shift.) Can someone tell me where the filler port is? what i thought was the filler port ended up spewing out a bunch of oil. i keep looking in books and online and can't find it. i still have "new guy" syndrome i guess.
Do something! Even if it's wrong!
the trans fill is a plug a bit above halfway up on the side, the box is not "filled", just up to the level of that plug - the only way oil could 'spew out' that port is if the plug weren't in
Bill- thank you. the plug i removed was on the passenger side of the transmission, about half way up...when i removed it, the oil started pouring out. So then i should assume it was overfilled?
Yes, if it leaked out there, it was overfilled- - - - -OR- - - - -there might be water in the bottom of case which will float the gear lube on top of it. If the vehicle hasn't been driven in a while, pull the bottom plug and see if there's water under the grease. It only takes about 3 quarts for a complete refill so it won't break the budget to do a drain and refill.
jerry, awesome. thank you. just got back from the store..going to chance the fluid now.
The actual level when cold should be 1/2" below the hole. That transmission has a tendency to dribble fluid out onto the clutch shaft so the level is important. I found 85W140 seems to work best for mine and it was rebuilt last year.
1951 1 Ton Completed
I fill mine by removing the floor pan, then removing the fill plug, (which is about 1/2 way up on the passenger side), then remove the gearshift, (by rotating the bayonet lock thing and pulling the gearshift out) and pouring the oil into the gearshift mount until it starts to run out the fill hole on the side.
If you have two people, you don't have to remove the floor pan.
If you have a pump and a lift, you don't have to remove the gearshift or the floorpan.
If you have a funnel with a long flexible snout, you can fill it from the side fill hole after removing the floor pan and the fill hole plug.
Kurt
If you buy the fluid in the tall plastic containers with the pointed top, you can fill it through the side easily. You can also use the container to install oil from other types of containers.
There's also pumps available at most flaps, and even a few hardware stores, that fit on the standard quart oil bottles for pumping gear oil into a trasnmission or differential. They run about $10.
Bill Burmeister
