0 members (),
110
7
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 17 New Guy | | New Guy Joined: Sep 2011 Posts: 17 | Hi Friends, I recently bought a 1966 Chevy C-10 and the fuel gauge was disconnected. After connecting the wiring to the back of the gauge, the wire to the fuse block and cleaning the ground at the sender unit and turning the key to the on position, the needle went to empty. I checked previous posts regarding to the fuel gauge and sender unit and performed the differents trouble shooting with the jumper cable to ground the sender unit and fuel gauge but the gauge needle never moved again. The gauge has good ground, 12 volts at the cable that connects to it and 12 volts at the fuse in the fuse block. As per previous post the ohms at the sender unit should be 0-90 and mine is reading 241. Based on the ohms reading the sender unit is not working properly. Let me know if there is any other test that I should perform. PLease advise.
Thanks | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | You might try posting this in the electric bay
| | | | | Joined: Sep 2011 Posts: 17 New Guy | | New Guy Joined: Sep 2011 Posts: 17 | | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The factory sending units and fuel gauges were 0-30 ohms, so you may have a non-factory sending unit of a different ohm range, than the factory fuel gauge. This problem is not uncommon. Do the ohm range test, through the float range on the sender, with your ohm meter. It should not exceed 30 ohms +/- a few ohms. | | | | | Joined: Sep 2011 Posts: 17 New Guy | | New Guy Joined: Sep 2011 Posts: 17 | I removed the sender unit and it says 30 ohms at the level float. I tested again and now is reading correct from 0 to 30 ohms. I installed the sender unit again, tested it and it is reading between 6 and 7 ohm. I connected all the fuel system and gage its still going to Empty. Any recommendations?
Thanks | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Make sure the guage is wired correctly.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Oct 2011 Posts: 19 New Guy | | New Guy Joined: Oct 2011 Posts: 19 | Hate to ask the obvious but are you sure there are at least a few gallons in the tank? my 65 would read empty well before the bottom of the tank | | | | | Joined: Sep 2011 Posts: 17 New Guy | | New Guy Joined: Sep 2011 Posts: 17 | I checked the ground and the gauge still reads empty. I added more gas to the tank and the ohms at the sender unit increased. I removed the gauge, connected to 12V and ground, and the needle never moved. Does the gas fuse at the fuse block has power with the ignition key off? I think the gauge it's not working. | | | | | Joined: Oct 2005 Posts: 116 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 116 | If your gauge reads full all the time( with the key on ) , that generally means you have a break in the wiring between the gauge and sending unit . If it reads empty all the time , generally you're looking at a short somewhere in the wiring between the two units . At least , that's what I've been told by people smarter than myself !
" The heart of the wise inclines to the right , but the heart of the fool to the left " - Ecclesiastes 10:2
| | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | if you put 12v across the guage and it didn't move it's probably shot. measure the resistance of the guage out of the circuit, if it's zero it's shot. | | | | | Joined: Sep 2011 Posts: 17 New Guy | | New Guy Joined: Sep 2011 Posts: 17 | Fuel gauge is working now. I found that the ground at the instrument cluster was bad.
Thanks all. | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | I had the same problem with my 64' and what I found that fixed it was replacing the wire between the units. Somewhere there was a break in the wire and as soon as it was done, I had smoke in the wire again and no more problems with the gauge. Hope you get yours taken care of and find what it takes to get it going again. Tramp | | |
