| | | Forums66 Topics128,060 Posts1,055,831 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 74 | Folks - are the rear fenders specific to 1 tons? I need a PS rear and don't know if it'd work.... | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No. Fenders are the same.
Bill Burmeister | | | | | Joined: Nov 2009 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 20 | Rear fenders for a 1 1/2 ton are larger than a 1/2 ton, as are the running boards. Front fenders are the same. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You have it backwards, 1 1/2 ton front fenders are larger, running boards shorter. 1 1/2 ton and larger do not have rear fenders, exept for the 1 1/2 ton Express trucks from the mid '30s. 1/2 through 1 ton use the same fender front and rear, running boards vary depending on bed type and length.
Bill Burmeister | | | | | Joined: Nov 2009 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 20 | I am not an expert and was only trying to relay what I know. I have two 1936 1.5 ton Chevrolet Panel Trucks and I use the same rear fenders as the 1.5 ton Open Express. The front clip is the same as the 1/2 ton, of the same year. When I bought the first truck, it only had one rear fender. It took me over a year to finally find a pair, mistakenly purchasing one from a 1/2 ton first. My second truck came with good fenders. The running boards for my 1.5 ton are longer than the 1/2 ton as my wheelbase is 131" compared to 126". Just my two cents worth. I can't speak for any other year, just what is in my storage.
Cheers.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | We cannot be certain what year Knedert is referring to, but, assuming it is 1947 Advance-Design, LONGBOX55 is correct.
Things are different between model-to-model characteristics in 1936 vs 1947.
Nonetheless, it is always nice to state the year in a start-off question (probably 30% of questions refer to years not listed in the original poster's signature or profile). Same goes for responses - we should try to qualify the year that our response pertains to.
