1 members (carbking), 142 guests, and 3 robots.
Topics128,266
Posts1,058,386
Members48,485
#783503 09/25/2011 9:19 AM
I
I Offline
I just picked up a 53 6500 with the engine removed. It had this cool looking Stewart Warner tach hose clamped to the steering column. I would like to put it in my 49 with a 6 volt 235. I do not know if the 53 was 6 or 12 volts.
The tach has two wires off of the back. One was hooked to the ground and the other was loose under the hood.
I am thinking it goes to the coil? or distributor?
Not really sure where else it could go?
Any ideas?
I think i got the links right to the pics.
http://i46.photobucket.com/albums/f129/Ibendcars/Green%2053%20Chevy/IMG-20110924-00107.jpg
http://i46.photobucket.com/albums/f129/Ibendcars/Green%2053%20Chevy/IMG-20110924-00114.jpg
My new 1949 Chevy One Ton Dump Truck. Still have it but parked, needs a new motor.
1953 2 ton parts truck Long Gone
1957 GMC LCF On 75 Cadillac Eldorado Frame
Updated Feb 2021
IB;
I will venture a guess; that tach is probably 12V. A lot of the earlier 6V tachs have separate sending units. Can you find a model number? A model number or some ID could give you something to research. If it is a "current sensing" instrument the "Dist Pri" wire usually connected to the hot side of the ballast resistor. There are a few gauge restoration shops on the net that might be able to steer you in the right direction. BTW, cool truck.
SimS
