0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 50 | I'm new to this site but it looks awesome , if this is not the right place to post this , please let me know . I just purchased a 55 chevy pickup 2nd series, the vin and engine #'s are not comming up on any web site i have searched (like 10 or more ).right now I really need to know if the engine is original ,so i can start working on it , It's a straight six with a single barrel carb and 3 speed manual . here is the # 04489I8F562.I'm guessing it's not the original engine , but everything else seems to be , and it is complete. thanks in advance for any help . 55redstove | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Looks like the engine is most likely a '56 passenger engine, as I'm inclined to beleive that the "2" at the end of the code may actually be a "Z".
Bill Burmeister | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you look here: Chevy Sixes and go to page 2, you will see a rusty engine on the left and a blue one on the right. Yours is like the one on the right except in Canada it is most likely a 216. Notice the buldge between #1 and #2 plugs on the head. That is specific to your motor. | | | | | Joined: Sep 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 50 | thanks for the info . I believe your right ! | | | | | Joined: Sep 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 50 | no buldges , and valve cover doesn't have the 2 top bolts ? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Was there a bulge in the upper middle of the 235/261 side cover all the way to 1962/63? Is that bulge needed after about 1958?
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I am sorry, I mixed up your post with another one. Disregard my comment about buldges. | | | | | Joined: May 2010 Posts: 85 New Guy | | New Guy Joined: May 2010 Posts: 85 | I had a similar issue with my 52, chevy 3100. In 52, the VIN was the number on the engine block....if you have the pink-slip, the vin on the pink, and the engine number should be the same...assuming they still used that number in 55.
Do something! Even if it's wrong!
