4 members (TooMany2count, MNSmith, moparguy, TexasJim50), 56 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#782930 09/22/2011 11:36 PM
I'm new to this site but it looks awesome , if this is not the right place to post this , please let me know . I just purchased a 55 chevy pickup 2nd series, the vin and engine #'s are not comming up on any web site i have searched (like 10 or more ).right now I really need to know if the engine is original ,so i can start working on it , It's a straight six with a single barrel carb and 3 speed manual . here is the # 04489I8F562.I'm guessing it's not the original engine , but everything else seems to be , and it is complete. thanks in advance for any help . 55redstove
55redstove #782934 09/22/2011 11:49 PM
Looks like the engine is most likely a '56 passenger engine, as I'm inclined to beleive that the "2" at the end of the code may actually be a "Z".
Bill Burmeister
LONGBOX55 #782978 09/23/2011 1:59 AM
If you look here:
Chevy Sixes and go to page 2, you will see a rusty engine on the left and a blue one on the right. Yours is like the one on the right except in Canada it is most likely a 216. Notice the buldge between #1 and #2 plugs on the head. That is specific to your motor.
1951 1 Ton Completed
LONGBOX55 #783324 09/24/2011 12:27 PM
thanks for the info . I believe your right !
truckernix #783325 09/24/2011 12:29 PM
no buldges , and valve cover doesn't have the 2 top bolts ?
55redstove #783337 09/24/2011 1:55 PM
Was there a bulge in the upper middle of the 235/261 side cover all the way to 1962/63? Is that bulge needed after about 1958?
tclederman #783425 09/24/2011 10:57 PM
I am sorry, I mixed up your post with another one. Disregard my comment about buldges.
truckernix #783497 09/25/2011 6:22 AM
I had a similar issue with my 52, chevy 3100. In 52, the VIN was the number on the engine block....if you have the pink-slip, the vin on the pink, and the engine number should be the same...assuming they still used that number in 55.
Do something! Even if it's wrong!
