6 members (Nick in Manitou, Phak1, Otto Skorzeny, Hush, MickeyP, 59 fleet), 66 guests, and 2 robots.
Topics128,188
Posts1,057,331
Members48,469
#78298 05/31/2007 9:55 PM
Ok so I am planning on lowering a 1964 chevy longbed c-10. It has rear coils and leaf springs. If i put 4" drop lowering coils in the rear would i have to also remove the leaf springs or can i leave them and it will still lower?
Stovebolt-It is painted
#78299 05/31/2007 10:16 PM
If you are talking about the overload half-leaf springs on the back of the axle, yes, if you lower it they will have to come off or be modified.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#78300 05/31/2007 10:56 PM
yea because my 64 chevy shortbed didnt have those leaf springs just the coils and so i just replaced the stock coils with lower ones..and the truck i want to lower is my Grandpas 64 chevy longbed 1/2..so ok i will have to just remove the whole thing and just put lowering coils to replace the stock ones?
#78301 05/31/2007 11:07 PM
The only way to lower a rear end is let the air out of the tires or put smaller tires on it. Unless you are not talking about the rear axle? wink
•1952 Chevrolet 3800 pickup
---All pictures---
#78302 06/01/2007 12:21 AM
hahahaaaa!!! yea that is one way or putting a ton of bricks in the bed..hahaaaa!
#78303 06/01/2007 4:59 AM
Good point about the bricks, and I thought I had thought of everything....
Seriously though, you will want to check your driveshaft angles once at the new ride height. You may need to correct pinion angle. Then centerline of the pinion and centerline of the engine/ transmission should be parallel for a one piece driveshaft.
This explains all the driveshaft questions you will ever have:
http://www.roadranger.com/Roadrange...=Installation%20Guide&Language=en_US
Grigg
---All pictures---
#78304 06/01/2007 5:08 AM
I got two tousand pound lowering blocks and twice pipes.
#78305 06/01/2007 1:39 PM
Bag it and notch the frame, The bags are cheap if you don't include a onboard compressor.
#78306 06/01/2007 2:50 PM
i dont know how to weld so bags are out of the question right now..but i use to have 4" lowering coils for the rear of my truck but i ended up putting a total of 6" drop on the rear of my truck with 3"drop coils in front..so i am givn my Gpa my 4" drop coils instead..so all he has to do is buy or cut the front ones..thats all smile thanks guys
