12 members (Joe H, Gray_Ghost, Woodcmiami, fonz8261, 2-Ton, cmayna, 55shaker, kades51, Forty9, NorthCoast3800, Robert Crandall, 1 invisible), 103 guests, and 3 robots.
Topics128,169
Posts1,057,037
Members48,458
#782712 09/22/2011 3:38 AM
I had my gauges rebuilt. There are two wires that go the the amp gauge and two wires to the fuel gauge. I know which two go to each gauge however does it matter which terminal each connects. Do not want to fry the new gauges.
thanks, Larry
Yes.
On the fuel gauge the post behind the Full mark goes to the tank sender. The hot wire goes to the post under the Empty. You will damage the sender if hooked up backwards. You will not hurt the amp gauge if the wires are backwards, it will just read discharge when charging. On my amp gauge it seems to work backwards of what I expected. The needle moves in the opposite direction of the current flow. The wire from the voltage regulator goes to the post under the discharge side. Yours may not work that way. Hook it up and turn on the ignition and see if it shows a slight discharge- if it does you are good. If it shows charge reverse the wires.
Chuck
Got it.
thanks, Larry
Ex Hall Monitor
Ex Hall Monitor
