7 members (klhansen, MNSmith, TUTS 59, Peggy M, Cletus1950, 2-Ton, mick53),
65
Mod | | | Forums66 Topics128,174 Posts1,057,047 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | I had my gauges rebuilt. There are two wires that go the the amp gauge and two wires to the fuel gauge. I know which two go to each gauge however does it matter which terminal each connects. Do not want to fry the new gauges. thanks, Larry
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 |
| | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | On the fuel gauge the post behind the Full mark goes to the tank sender. The hot wire goes to the post under the Empty. You will damage the sender if hooked up backwards. You will not hurt the amp gauge if the wires are backwards, it will just read discharge when charging. On my amp gauge it seems to work backwards of what I expected. The needle moves in the opposite direction of the current flow. The wire from the voltage regulator goes to the post under the discharge side. Yours may not work that way. Hook it up and turn on the ignition and see if it shows a slight discharge- if it does you are good. If it shows charge reverse the wires.
Chuck | | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 |
