0 members (),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | 59 electric wiper, it has 3 spade conectors and I can not fine any info as to where they go. Thanks Larry | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I have dealt with several TF units, maybe 59 is different. The ones I have tested have one wire and one cable which operates a hi/lo/park switch "inside" the unit. The one wire is the hot and the case is GND. The Maintenance manual shows one wire. Post a picture, maybe it is not a 59 unit? If 59 is different than manual, this is my guess:, one terminal would be hi, one low and one park if case is ground. This would mean you would have a switch on the dash not a knob and cable setup. But according to the manual, it is not a 55-59 unit.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the 58-9 electric wiper unit was a transition to the 60-66, unlike the 55-57 unit - pic here, and it does use an electrical dash switch .... no idea about wiring, but it may be in the 58 shop manual Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I found 1960 and up diagrams say two wires from motor. One to ignition switched pos and one to wiper switch. A third wire may be for washer or 2 speed? One diagram says white to wiper switch and pink to ign switched pos. Do the wires have these colors? I think the picture from squeeze shows a yel and a blk. But they may not be pigtail leads just assy interconnects. Someone who has a 58/59 shop manual may post the info. Good luck.
