| | | Forums66 Topics128,290 Posts1,058,566 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 121 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 121 | Doing lots of research and have been reading all I can find relating to a T5 swap and still have some questions. I have a 55 3100 with a 235, factory 4 speed and 4:11 rear. What T5 will work the best? I have a 90 S10 with the 4.03 1st gear, 0.86 5th for a swap. Will this be ok or should I look at a 85-89 with the 3.76 1st and .72 5th or a Camaro V8/V6 to do a front shift conversion with the S10 parts?
1955 Chevy 3100
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The mid 80s S-10 is very common & good. It has .072 o-drive. It has the mechanical speedo. Most 88 & all after theat had the elec. speedo drive & most had the >086 o-drive which is not good with 4.11 rear end. Look on the tag 1352-145 is the best one to use. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2008 Posts: 121 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 121 | The mid 80s S-10 is very common & good. It has .072 o-drive. It has the mechanical speedo. Most 88 & all after theat had the elec. speedo drive & most had the >086 o-drive which is not good with 4.11 rear end. Look on the tag 1352-145 is the best one to use. Thanks and managed to find a pair of them, 145`s, last week. Also bought a spacer so I don`t have to trim the input shaft or retainer thus allowing an easy replace if I have to swap it out.
1955 Chevy 3100
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | You might want to pick up a driveshaft from a short bed mid 80's S10 to give you the front slip yoke for the t5. On my 54 conversion with a 145 t5 box to a Camaro (88) diff, the driveshaft was a perfect fit. You might get lucky......
Dave | | |
