0 members (), 79 guests, and 0 robots.
Topics128,035
Posts1,055,560
#782639 09/22/2011 12:24 AM
I've discovered a broken mechanical fuel pump on my 52'. I haven't started the truck since I've owned it and figured it didn't work because the previous owner had put an electric pump on it. Assuming the broken off pump arm is inside of the engine, would it cause any problems? Would it be in the crank case?
have you taken off the pump and seen that the arm is "broken"? they do wear enough to quite pumping .... if it's snapped off, there could well be other problems, but yes, it'll be laying in the pan .... of course you should pull the pan and find out, it likely needs cleaning out anyway wink
Are you saying you removed the pump and the arm wasn't on it? Maybe the p.o. removed it when he put the electric pump on. Does it look like it was broken off or cut off?
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Yup, when I took the pump off the arm was missing. The pump arm was either sheered off or cut off. The pump doesn't look original and appears to be mounted upside down. Doesn't the bowl part sit below the mounting bolts with the pump arm pointing down?
I just had the pan off my 235, and found a fuel pump arm!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
If it has a glass bowl it sits on top.
Cletis #782771 09/22/2011 11:28 AM
As Cletis posted, here is the orientation of the fuel pump when it attached to the block. You cannot see the orientation of the lever in that illustration; however, you can see the lever and glass bowl on this dual-action fuel pump.
The new pump I have is an Airtex Model 4149 found at www.napaonline.com. It's a no vacuum single action pump.
Does anyone have pics of an aftermarket mechanical fuel pump mounted on a 216?
I just got a new oil pan gasket and plan on taking the pan off soon to check for the missing fuel pump arm. Might be a good time to inspect the oil pump.
Update: Pulled the pan off and No broken fuel pump arm! Found about a 1/4" of sludge in the bottom of the pan which was expected on a vehicle this old, everything else looked great. Just put a fresh coat of primer/paint on the pan while I had it off. Should have it back on the engine in no time.
