1 members (JW51), 137 guests, and 2 robots.
Topics128,049
Posts1,055,741
So the PO who owned the truck before me decided it was better to weld the lower aft part of the front fender to the sill instead of bolting it. After I sawed through the weld, I can see that the caged nut and bolt is missing. Anyone have a source or picture of what is suppose to be there?
[IMG]http://i765.photobucket.com/albums/xx297/hb32/DSCF4551.jpg[/IMG]
1955 Chevy 3100
Give me ambiguity
or give me something else
hb - there's a correct patch piece available from most vendors to replace the lower foot or so of that brace - old car centre will have it .... you might need the bracket that bolts to as well
Thanks Bill. the piece looks great except for the missing threaded insert. Does it float or is it fixed?
1955 Chevy 3100
I recall it as a weld nut, no movement, but it could be done with a cage nut to allow a little fiddling for fit, and it'd probably be easier as with that face damaged you can't tell exactly where the hole was positioned, and the original had a hole barely bigger than the bolt
Floating weld nuts, McMaster Carr has a good selection, coarse and fine thread
http://www.mcmaster.com/#bridge-weld-nuts/=e5n8ys
