7 members (JW51, TUTS 59, 3800GUY, Otto Skorzeny, cmayna, 52GMC35424JD, 1 invisible),
105
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 121 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 121 | So the PO who owned the truck before me decided it was better to weld the lower aft part of the front fender to the sill instead of bolting it. After I sawed through the weld, I can see that the caged nut and bolt is missing. Anyone have a source or picture of what is suppose to be there? [IMG] http://i765.photobucket.com/albums/xx297/hb32/DSCF4551.jpg[/IMG]
1955 Chevy 3100
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 |
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | hb - there's a correct patch piece available from most vendors to replace the lower foot or so of that brace - old car centre will have it .... you might need the bracket that bolts to as well
Bill | | | | | Joined: Oct 2008 Posts: 121 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 121 | Thanks Bill. the piece looks great except for the missing threaded insert. Does it float or is it fixed?
1955 Chevy 3100
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I recall it as a weld nut, no movement, but it could be done with a cage nut to allow a little fiddling for fit, and it'd probably be easier as with that face damaged you can't tell exactly where the hole was positioned, and the original had a hole barely bigger than the bolt
Bill | | |
