2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78236 05/30/2007 1:29 PM | Joined: Aug 2006 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 98 | I've got two '60 trucks that I'm making into one good one.Was working on the rearend of one last nite and noticed that rearend is differant from the other one.Both are 1/2 tons.Can someone tell me what the differances are?Don't know if this helps but one has an overload spring running across the top of it.
Thanks, Gary | | |
#78237 05/30/2007 2:21 PM | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | Are they GMC or Chevy? I'm not sure exactly what year the Dana 44 was available, but it was an option that came with Positraction. The center section of a Dana has a cover on the back only...the other style of rear end has a drop-out front center section, and a cover in the rear. It's more round, too. If you have the choice, go with the Dana--it was used in everything from Studebakers to Mail jeeps to recent Jeep wagoneers, Ford trucks. and a ton of other vehicles. They're about the cheapest rear end to build, parts are readily available for them, they're strong, and you can get a good Posi unit and most any gear ratio you'd want. -Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | |
#78238 05/30/2007 2:31 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | 60-62 Chevy also used an Eaton in the 1/2 tons. | | |
#78239 05/30/2007 10:06 PM | Joined: Aug 2006 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 98 | They're Chevys.Thanks for the help. | | |
#78240 06/02/2007 6:00 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
