3 members (Hotrod Lincoln, BC59, 1 invisible), 134 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
#78236 05/30/2007 1:29 PM
I've got two '60 trucks that I'm making into one good one.Was working on the rearend of one last nite and noticed that rearend is differant from the other one.Both are 1/2 tons.Can someone tell me what the differances are?Don't know if this helps but one has an overload spring running across the top of it.
Gary
Current project . . . 1960 LB stepide Chevy
#78237 05/30/2007 2:21 PM
Are they GMC or Chevy?
I'm not sure exactly what year the Dana 44 was available, but it was an option that came with Positraction.
The center section of a Dana has a cover on the back only...the other style of rear end has a drop-out front center section, and a cover in the rear. It's more round, too.
If you have the choice, go with the Dana--it was used in everything from Studebakers to Mail jeeps to recent Jeep wagoneers, Ford trucks. and a ton of other vehicles. They're about the cheapest rear end to build, parts are readily available for them, they're strong, and you can get a good Posi unit and most any gear ratio you'd want.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
#78238 05/30/2007 2:31 PM
60-62 Chevy also used an Eaton in the 1/2 tons.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#78239 05/30/2007 10:06 PM
They're Chevys.Thanks for the help.
#78240 06/02/2007 6:00 AM
posted 20 March, 2007 19:00
10, 12 and 14 bolt refers to rear ends.
the 8.x is the ring gear diameter size.
5, 6, 8 lugs refer to rim/ wheel holes.
http://www.drivetrain.com/GMtrkratio_posidata.html
http://www.wilcap.com/diff.html
http://www.mag-hytec.com/differential%20covers.htm
http://www.nastyz28.com/decode.html
hope this helps
Jim & Caroline
