3 members (1955 1 Series, Bill Hanlon, 1 invisible), 361 guests, and 4 robots.
Topics128,160
Posts1,057,054
Members48,463
1 Offline
hello, got the engine outta my truck, but, i can't seem to get the bell housing off. it's a 1941 235. i've got a line on a 1954 235 to take it's place. it is my understanding that my bell housing will bolt right up to it. i've removed 4 bolts. 2 on the top of the bell housing on the outside, and 2 on the bottom inside. what's holding it on? i hope it doesn't involve turning the flywheel, it's been stuck for 40 years or so. hence, the engine swap. thanx in adavance. marc
http://s1233.photobucket.com/albums/ff393/fletch41/
1941 Chevy 1.5 Ton, (soon to be flatbed), dubbed the "USS Coral Sea" which I served on while in the military. wink ~m
wink
~fletch
Remove flywheel, then remove the last bolts behind it that you may not have access to otherwise.
•1952 Chevrolet 3800 pickup
---All pictures---
Riding in the Passing Lane
If the engine is stuck it is difficult to remove the clutch to get to the flywheel. There was a thread on this a while back. Guys had various ways of doing it. My method is if the old engine is no good anyhow. Remove the oil pan & wack the crankshaft in front of the rear main.
1972 Chevy c10 Cheyenne Super
1fletch also has part of this question going in another thread
where I suggested he start gently, by seeing if the crankshaft would free up easily by removing the rocker-arm assembly and taking any stuck valves out of the equation...
1953 Chevy 3100
Father and Son project
46 GMC 303 1.5T
1 Offline
this is killing me. before i read these responses i was just gonna break out the sledge. the engine is toast. i gotta new one. the head is removed as well as the oil pan. i am going to disassemble it as far as i can and look for something to hit with the sledge that isn't an integral part of the bell housing/flywheel/clutch assembly. i've got the engine on it's side for easier access. i will check back here periodically in case someone takes pity and points me in the right direction. thanx for your input so far. ~m wink
wink
~fletch
take the oil pan off, unbolt the conrods and she should spin,
if not undo the main bearing caps and try again...
GMC: Get More Cash...
1958 GMC
My Webshots photos
1 Offline
thanx shark, (and you other guys), i did just that and was able to take the crank out in it's entirety. then i was able to remove the bell housing, clutch, and flywheel. i completely disassemble it to see the inside of the engine. a confession, this is my 1st engine removal, and disassembly. learned a lot. thanx, maybe i DIDN'T bite off more than i can chew. we'll see.
wink
~fletch
