1 members (Hotrod Lincoln),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 84 | I needed to replace both door strikers in my '51. The screw that holds it on, goes through the striker plate and screws into a piece of metal with two holes in it. Does anyone know where I can buy two of them? I have one that is stripped and one with a broken head in it. I checked Classic, Carter's and LMC. No luck
Ideas? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Probably cage nuts. You can replace them but you'll need to gain access to the back side of the pillar if you don't already have access. I'm not familiar with the construction of that part of the truck so I don't know how difficult it is to access the back.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | They are not cage nuts but a very specific lock plate that is drilled and threaded. They are not reproduced as far as I know send me a PM I can probably help you out here is a picture of them. http://good-times.webshots.com/photo/2492688590102454676vhyrgAhttp://good-times.webshots.com/photo/2432157460102454676VeLKTNThere are two styles 1947-50 which are 1/4" thick and the later 1952-54/55 versions which are about 3/16" thick. They fit in a pocket inside the body, stick your head in behind the door and you can see them. They are serrated to lock tightly into place in the pocket once you have the latch/door aligned. | | |
