| | | Forums66 Topics128,166 Posts1,057,092 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 40 | I'm looking to build a speedster out of a 31 Chevy car chassis. I want to use a 1955 235 6 cylinder instead of the original 1931 6cyl. I would like to use the original transmission and torque tube. Any idea as to what is involved in changing it out? I would like to keep the bell housing too if possible. Jason | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There are no stock bell housings that will bolt to a 235 and a 31 trans.
I put a 235 in a 1929 using a 1938-46 truck bell housing and a 1937-39 truck 3 speed. This worked well. It was necessary to trim the front of the rear cross member for pan clearance.
This should work the same in your 31.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2006 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 40 | Will the truck transmission U-joint be the same?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You will use the 37-39 front yoke and your 31 rear yoke. They will bolt together.
