2 members (54farmtruck, klhansen), 362 guests, and 2 robots.
Topics128,168
Posts1,057,098
Members48,463
I'm looking to build a speedster out of a 31 Chevy car chassis. I want to use a 1955 235 6 cylinder instead of the original 1931 6cyl. I would like to use the original transmission and torque tube. Any idea as to what is involved in changing it out? I would like to keep the bell housing too if possible.
Jason
The aviation artist guy in Houston that loves old trucks even more than planes. www.jasonbarnettartist.com
There are no stock bell housings that will bolt to a 235 and a 31 trans.
I put a 235 in a 1929 using a 1938-46 truck bell housing and a 1937-39 truck 3 speed. This worked well. It was necessary to trim the front of the rear cross member for pan clearance.
This should work the same in your 31.
My Blog
Will the truck transmission U-joint be the same?
You will use the 37-39 front yoke and your 31 rear yoke. They will bolt together.
My Blog
