5 members (J Lucas, Brian Moore, Pete1946, Otto Skorzeny, Hotrod Lincoln), 124 guests, and 3 robots.
Topics128,072
Posts1,055,903
Members48,429
#781833 09/19/2011 12:38 AM
DR
Offline
I am assembling a 1955 Chev Pick-up, at this time I am working on the engine. Today I put it back on the frame along with the radiator. When I got it in place I noticed that the fan blade goes to the bottom of the radiator. I know I have the proper fan and radiator, what I don't know if the water pump is correct. Has anyone heard of a high mount water pump for the 235 6 cylinder.
Figure I need to address this before I go any further.
DR
DR #781840 09/19/2011 12:52 AM
hello DR my truck has a early 261 engine with a (high)water pump.the block has two round water passage holes.if you go to Patricks website it is on the links section.he has a section on the high and low waterpump issue.i believe he sells a plate to convert to high mount pump.i just replaced my pump and got it at NAPA for about $40.00 good luck Andy
DR
Offline
Do you have apart number from NAPA?
DR #781853 09/19/2011 1:38 AM
Leo Offline
Moderator
Moderator
Is there a concern with how it is? My fan sits a bit low as well but cools the engine (261) just fine.
I believe pre68dave sells these, contact him on this site.
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
