| | | Forums66 Topics128,050 Posts1,055,639 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 26 New Guy | | New Guy Joined: Jul 2011 Posts: 26 | I am assembling a 1955 Chev Pick-up, at this time I am working on the engine. Today I put it back on the frame along with the radiator. When I got it in place I noticed that the fan blade goes to the bottom of the radiator. I know I have the proper fan and radiator, what I don't know if the water pump is correct. Has anyone heard of a high mount water pump for the 235 6 cylinder. Figure I need to address this before I go any further.
DR | | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | hello DR my truck has a early 261 engine with a (high)water pump.the block has two round water passage holes.if you go to Patricks website it is on the links section.he has a section on the high and low waterpump issue.i believe he sells a plate to convert to high mount pump.i just replaced my pump and got it at NAPA for about $40.00 good luck Andy | | | | | Joined: Jul 2011 Posts: 26 New Guy | | New Guy Joined: Jul 2011 Posts: 26 | Do you have apart number from NAPA? | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Is there a concern with how it is? My fan sits a bit low as well but cools the engine (261) just fine. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I believe pre68dave sells these, contact him on this site. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
